Piping Design in Solid Edge
Rahul Kulkarni, Manager, Product Design, Pune Center, Siemens PLM Software
Level: Basic
Learn how to quickly design piping routes using the XpresRoute environment in Solid Edge. There will be a live demo of the pipe design workflow that includes creation of a path (including gradients), assigning pipe attributes and fittings, modifying the path, fittings or pipes, adding or removing fittings and pipes and creating a piping report. The session will not only use pipe and fittings from the standard parts library, but also demonstrate how to create your own pipes and fittings and use them from the local disk. If you are a designer and interested in pipe design, this session is for you.
