Preparation for the Solid Edge Professional Certification Exam
MLombard
Retired
Take advantage of this instructor-led session, designed to help you prepare to take the Solid Edge Professional Certification Exam.  This session will make you aware of scenarios you may encounter during the exam and suggest how you might approach some of the challenges.  Combine this session with your Solid Edge skills and walk away with the satisfaction that you’re on your way to becoming a Solid Edge Certified Professional.
Comments
Solution Partner Visionary Solution Partner Visionary
Hi MLombard
The attached pdf was very much helpful in getting through the certification exam.
Thank you
Hasanka Mapa
Solid Edge ST9 Certified Professional
Contributors
