Print Keyboard Shortcuts
Question
Is there a way to print out all of the keyboard shortcuts?
Answer
If you go to the Customize menu on the Quick Access Toolbar and select Customize, go to the Keyboard tab on the dialog and then select “Choose commands from:” “All Keyboard Assignments”, you can print out all of the keyboard commands for the selected environment. The environments can be selected from the “Environment to customize” dropdown at the top of the dialog.
Contributors
