Reaching Beyond the Barriers of Parametric Assemblies
Frederic Menage, Applications Specialist, designfusion
Level: Basic
This session will demonstrate how the command ‘move to synchronous’ can be safely used when a parametric assembly doesn’t offer a valid solution for a specific modification. It will also suggest an ideal construction model for parametric assemblies, based on key concepts like link context and minimal source of reference. Experienced Solid Edge users who regularly need to revise existing models with new dimensions will benefit from attending.  They will learn techniques and solutions to quickly adjust their model when an unforeseen change is requested. The presenter will use live demonstrations with Solid Edge assemblies to teach how to build sturdier parametric models in general.
Contributors
