Red Exclamation Point on Display Tab
Question
What does the red Exclamation Mark (!) in front of a part in the Display tab of the Drawing View Properties dialog mean?
Answer
This indicates that there is an issue with respect to that model. If you right mouse click on the model in this dialog and select Status, it will tell you what the problem is.
Contributors
