Relocate Origin of Coordinate Dimension
Question
How do you relocate the origin of a coordinate dimension group?
Answer
You can do the following to relocate the origin of a coordinate dimension group:
  1. Start the 'Attach Dimension' command
  2. Select the origin dimension of the coordinate dimension group
  3. Select the key point for the new origin and place the dimension
This will automatically adjust all dimensions with respect to new origin.
Contributors
