Removing the Origin Dot
Question
How to remove the origin dot in coordinate dimensions?
Answer
To remove the dot located at the origin of a coordinate dimension group, do this:
  1. Go to View tab> Styles
  2. Select "Dimension" as the Style Type
  3. Select the style you use from the "Styles" list
  4. Click Modify
  5. Go to the Lines and Coordinate tab
  6. Under the Coordinate area, change the Common Origin from Dot to None.
  7. Click OK and Apply.
Contributors
