Resilient Assembly Design
Resilient Assembly Design (RAD) is a new CAD-neutral design strategy that expands the concepts of the Resilient Modeling Strategy (RMS). Learn about:
  • Inside-out design that focuses on the critical surfaces
  • Multi-body design that preserves the feature tree upon publishing
  • Skeleton models that change shape as the design evolves
  • Shape models that manage the appearance and functionality of the outside skin
  • Efficient design team workflow that enables analysis and model checking
