Resize a Parallel Reference Plane
Question
How can I resize a parallel reference plane that was pulled from a very small face?
Answer
With the Select Tool, select the plane that you want to resize. This will cause the Quickbar for that plane to appear in the graphics window. Select Dynamic Edit from the Quickbar. This will allow you to manually key-in the new X and Y
values of the plane, or, you can select the grab handles on the plane and drag them to resize the plane.
Contributors
