Reverse Engineering in Solid Edge
MLombard
Retired
Come learn about Reverse Engineering, a new Solid Edge beta-stage add-in that provides tools to convert STL mesh data to a Solid Edge part model. See how to import an STL file, repair STL mesh, identify shapes, extract surfaces, create a construction body, and convert it to a design body that is ready for editing and use in Solid Edge.  At the end of the session, you will have an opportunity to help direct future development of these tools.
Comments
 How to enable Reverse Engineering in ST 10
