SAT file size
Question
Why isn’t my SAT file imported part the correct size?
Answer
When translating SAT parts into Solid Edge, the options dialog box allows for Scale Override Values of 1, 25.4 or 1000. This is to account for unit differences between the original file and the Solid Edge file units. Setting the scale correctly should result in a correct size model within Solid Edge.
Contributors
