SEU: 126 - The Design Secrets Behind Stylized Products You Use Every Day - Olivier Pellerin
Olivier Pellerin, IT Innovation Manager, Groupe SEB
One of the lead designers responsible for creating innovative products like Krups coffee machines and Wearever cookware will take you behind the scenes on how these products are designed.  You will learn how to create stylized designs from sketch creation, 3D curve creation, surfacing, surface analysis and the importance of curvature continuity.  Also covered will be how to design in order to meet plastic injected manufacturing requirements.  This session will be a mix of lecture and live demonstration and is perfect for anyone responsible for designing stylized products.
