SEU13: 111 - Getting the Images You Want Using Lightworks Rendering Inside Solid Edge - Clive Davis
Clive Davies, Business Development Director, Lightwork Design Limited
This session will show how to use the rendering functionality inside Solid Edge to improve the presentation of your 3D designs. Aimed at both new and experienced users, you will see how to quickly access the rendering functions to produce the images that you need. The rendering in ERA (Explode-Render-Animate) has been designed to give you quick access to advanced functions without the need to become an expert on rendering and the creation of an image should fit naturally into your workflow. You will see how to achieve that in this session. The presentation will be built around a number of live demos to show how these functions can be accessed along with a number of pre-rendered images showing the effect of the various settings.
Contributors
