SEU13: 121 - How Solid Edge Helps Product Design at Walworth - Hugo Perez
Hugo Perez, Senior Product Engineer, Walworth
See how this customer uses Solid Edge for product design.  This session will show how Walworth, a leader in valve design since 1842, implemented Solid Edge for the design of expanding gate valves.  Learn how Solid Edge was implemented and adapted to meet specific design needs while improving the design and detailing process within the engineering department.  The results helped Walworth reduce design times.  This session is ideal for any customer looking for new ways to improve their own productivity.
Contributors
