SEU13: 125 - Best Practices in Developing Cast Machine Models - Nate Emler
Nate Emler, Engineering Programmer, Ariel Corporation
This session will demonstrate the ordered modeling practices of Ariel Corporation in creating casting and machining models in the ordered part environment.  It will have a live demonstration of how to utilize commands such as Part Copies, Family of Parts, Assembly Features, and Open Profiles to speed up the change process and minimize the chance of modeling mistakes.  The goals are for new and experienced designers to learn how to create a linked casting and machining model that is robust but still easy to update.  This session is perfect for a designer of any skill level who wants to learn how to apply proven techniques in machining casted parts.
Contributors
