SEU13: 408 - Get a Grip on Using Standard Parts - Mark Thompson
Mark Thompson, Solid Edge Field Support, Siemens PLM Software
We will take a look at the standard part loading options, using the configuration wizard, how to create a database, setting up standard parts folders, using the standard parts administrator, and the different options of loading standard parts to the database.  Attendees will see several live examples of how to get the most out of standard parts as well as leaving with a better overall understanding of how to install and use Solid Edge standard parts.
Contributors
