SEU13: 412 Getting Started with Synchronous Technology - Kevin Grayson
Kevin Grayson, Applications Engineer, Siemens PLM Software
With synchronous technology, you no longer have to choose between constraint-driven or history-free modeling. You no longer have to be a programmer to reuse a model. And you no longer need to worry about using data from multiple CAD systems. This session will cover the key concepts in synchronous technology: geometry creation using regions and model-applied dimensions, mastering edits using Live Rules and the Solution Manager, and how to design using a combination of ordered and synchronous features. Best practices in how to manage your model by preserving geometric conditions will also be covered.
