SEU13: 601 - Assembly Design in Solid Edge A Hands-on Experience - Mark Thompson
Mark Thompson, Solid Edge Field Support, Siemens PLM Software
This is a hands-on session where we will visit exciting new Solid Edge ST6 assembly enhancements that will make you more productive while building assembly structures. You will experience new ways of adding part features from the assembly level as well as new modeling improvements while in-place activated into components of the assembly. We will also explore a more productive way to work with very large assemblies. You will walk away with a better understanding of the tools available to help accelerate your design process.
Contributors
