SEU13: 605 - Solid Edge Simulation A Hands-on Experience - Mark Thompson
Mark Thompson, Solid Edge Field Support, Siemens PLM Software
In this hands-on session, you will walk through Solid Edge simulation using different examples along the way to gain a better understanding of its capabilities. You will also see the new enhancements in ST6 and discover how the user can now optimize their design without compromising their analysis results. Solid Edge simulation was designed for the design engineer to be able to quickly run an analysis on their models and get results fast. In this session, you will experience just how easy it is to use!
Comments
I´m a new user. Could ou please help me. Where do I get files the tutoriais is refered to?
Thanks.
Contributors
