SEU13: 612 - Stylized Design A Hands-on Experience - Doug Stainbrook
Doug Stainbrook, Solid Edge Field Support Team Leader, Siemens PLM Software
In this hands-on experience, we will explore modeling a stylized part using many of the enhancements in Solid Edge ST6. We will look at how to use the tools in ST6 to create smooth and flowing stylized parts like you see on the shelf at your local department store. We will also take a look at some new visualization and inspection tools to make sure that your part is exactly what you had in mind at the beginning of your design process. If your company makes stylized components, you will want to be sure to check this out!
Contributors
