SEU13: 621 - Creating Photo-Realistic Images A Hands-on Experience - Doug Stainbrook
Doug Stainbrook, Solid Edge Field Support Team Leader, Siemens PLM Software
In this session we will use the built-in rendering engine in ERA to create photo-realistic renderings in Solid Edge. We will look at many of the lighting, shadow, and environment options that can be used to give your virtual products a real-to-life look. We will even take a look at how you can add your own photo as a background image to put your assembly in its natural environment. Don't worry, you won’t need a PHD in photo rendering to follow along and understand the concepts and settings covered in this class.
Contributors
