SEU13: 622 - Designing with Multi-Bodies A Hands-on Experience - Doug Stainbrook
Doug Stainbrook, Solid Edge Field Support Team Leader, Siemens PLM Software
Multi-body modeling was added in Solid Edge ST5 and in this session we will explore a couple of different scenarios on how multi-body modeling can be used. First we will use multi-body modeling to create a fairly complex part much faster and easier. We will also look at how a particular component may actually consist of multiple bodies, which are needed for manufacturing; however these bodies would actually be a single part number in a parts list. This is powerful functionality that you don’t want to miss out on! Come and see how it works!
Contributors
