ST7: 3D Sketching in Solid Edge
Rahul Kulkarni, Manager, Product Design, Pune Center, Siemens PLM Software
Level: Basic
Tired of creating multiple 2D sketches on several different planes and connecting all of them to create a 3D sketch? If yes, then this session is for you. Learn how to design faster using the 3D sketching capabilities in Solid Edge. There will be a live demo of the 3D sketching capabilities that includes using the various 3D sketching commands, applying relationships, locking the orientation using a triad, snapping to existing geometry and applying dimensions.  Use these 3D sketches in modeling, in surfacing, for placement of components in assembly or for creating tubes, pipes and frames.
