Sheet Metal Design: A Hands-on Experience
Steve Webb, Solid Edge Field Support, Siemens PLM Software
Level: Basic
Does your company design sheet metal parts? Do you need a better understanding of how to model those parts using sheet metal design? If so, then this hands-on session is for you. We will walk through step by step modeling sheet metal using Solid Edge ST7. We will look at tools that will take a part model and convert it into sheet metal, and how synchronous technology will help you create sheet metal faster and easier than you ever have in the past.
Contributors
