Sheet Metal Design Using MacSheet-SEG5
Ashish Kelkar, Senior Developer, CADMAC
Level: Basic
Shorten the time to production! MacSheet-SEG5 is an add-on sheet metal design application for Solid Edge. Its “easy to use” user interface allows sheet metal designers and manufacturers to rapidly generate NC data from any 3D model designed in Solid Edge's Synchronous Technology.  Sheet metal models can be created semi-automatically from 2D DXF or even solid models from other CAD system. Led by CADMAC- one of Japan's leading sheet metal CAD/CAM companies- this session's live demonstrations will prove that sheet metal model creation is easy and fast in MacSheet-SEG5.
