Showing mass / volume properties of all bodies within a multi-body file show
Question
Why does the mass / volume properties of all bodies within a multi-body file show
in an Assembly file, where only one of the bodies is selected to display?
Answer
Regardless of what body is chosen to display in the assembly, all bodies within the file are calculated in the Physical Properties of the Part or Sheet metal file. If you do not want this to occur, you must “publish” the bodies to their own individual Part or Sheet metal file.
