Simplifying the Design Process with Multi-body
Using Multi-Body parts to create conceptual designs with minimum manufacturing data reduces the design time dramatically while providing all the necessary information to review and optimize the product.  Adding the manufacturing data after the product design is approved is a much simpler and faster process than starting from scratch. You must see this remarkable and efficient approach using Multi-Body in Solid Edge.
