Simulation for Design Engineers
Do you want to reduce physical prototypes, reduce material used in your products to reduce cost, or just ensure that you designs are strong enough? This hands-on session is an ideal introduction to the Simulation tools built into Solid Edge that will broaden your skills. We’ll cover a range of topics, from setting up an analysis to reading results, including the use of tools such as automatic optimization of your design.
