Solid Edge Built-in Data Management
MLombard
Retired
Learn more about what's new with the new built-in data management tools in Solid Edge.
Comments
Dreamer
Dreamer
Hi
We use the built in data management tool in ST10, occassionally and probably poorly, but i'd like to know if the system should update the associated draft files (on sub-assemblied and parts) when carrying out a 'Saveas' task on an existing assembly model that is going to be used as the basis for a new assembly?
David
