Solid Edge Everywhere with VDI
MLombard
Retired
Do your large and complex assemblies have you tied to a bulky workstation for performance? Does collaboration with coworkers have you on a short leash with your company network? Does design security stop you from leaving the office? VDI (virtual desktop infrastructure) lets you take Solid Edge everywhere, while maintaining workstation performance and security. Imagine the ability to work at your desk, then pick-up right where you left off on tablet while you answer questions on the assembly floor, use your smartphone to lookup a design, and even safely take your design work home or to a customer location. All at the same performance, regardless of location or device. This session will give you a high level overview of VDI and then demonstrate the possibilities on different devices
Contributors
