Specifying the active body in an assembly
Question
How do I specify the active body when a multi-body component is placed in an assembly?
Answer
The active body can be changed using the command 'Activate Assembly Body'. In-place-activate the component from assembly. Expand the list of design bodies. Right Mouse Click on the body you would like to be the active body and select 'Activate Assembly Body'.
