Stop the Orientation from changing
Question
When I start a profile-based feature, is there a way to keep the view orientation from
changing to the sketch plane?
Answer
Yes. Go to the General page of the Solid Edge Options dialog and uncheck "Orient the window to the selected plane".
Contributors
