Structural Frames and Welding: A Hands-on Experience
Kevin Grayson, Solid Edge Technical Consultant, Siemens PLM Software
Level: Basic
Fabricated steel or framework is a common design challenge.  In this hands-on session we will take a look at how Solid Edge can help you meet these challenges with some new tools offered in ST7.  We will spend some time building a framework, and then look at adding weld beads and labels to the design.  When complete, we will place our design into draft to create the detailed drawing with balloons and parts list.
Contributors
