Synchronous Sheet Metal Design
MLombard
Retired
Learn sheet metal design using Synchronous tools - a fabrication-ready process. Form parts from your design or existing 2D legacy data. Using Multi-Body, we'll explore the multiple part design process and compare to the assembly design process of sheet metal parts.
Contributors
