Synchronous for Skeptics
Matt Lombard, Siemens PLM Software
Level: Basic
Synchronous technology is really what sets Solid Edge apart from the rest of the CAD industry right now. If you are not using ST, you are leaving out the best part of the tool that you have right in front of you. In this session you will see where synchronous saves you massive amounts of time or enables edits that with a history-based system would be impossible.
