Turning off flow lines in an exploded drawing view
Question
How can I turn off flow lines in an exploded drawing view?
Answer
Right click the drawing view, select properties-> select Annotation Tab-> Uncheck 'Show flow lines' option.
Comments
This does not work for non-exploded views flow lines and wire paths are visible.
Contributors
