Underline for Caption in Drawing View
<H2>Question</H2> <P><STRONG>Where is the underline for the Caption on a Drawing View in ST4, or ST5?</STRONG></P> <H2>Answer</H2> <P>There is really not an “underline”, but a “Separator” function that appears to underline the caption on a drawing view. The intent of this option is to provide a line that separates the Primary and Secondary captions, should both be used at the same time. The location for this function is on the Drawing View Properties dialog/Caption (tab)/check the "Separator" box and you'll have the underline.</P>
