Wire Harness - The Orange Way
This session will demonstrate the basics of Wire Harness and how it is used at Ditch Witch. We will explore the benefit of Wire Harness to predetermine harness routing, retention, and the ability to determine accurate wire lengths. We will also explain the Ditch Witch harness design process and how harness information is used throughout our organization. We will be working directly in one of Ditch Witch’s current projects. So, come by and take a look at how Wire Harness can take your design to the next level.
