Bug - Support For Frame
Hi there,
I'm seeing a problem when an assembly contains frame elements, can't be viewed. An incomplete assembly file [have only tested this with one example file though] is shown....the rest of the assembly parts are visible, just the frame elements are missing.
See images below.
Portal assembly model display
 Solid Edge assembly model display
Is this a known issue, or am I not doing something correctly when uploading?
Re: Enhancement - Support For Frame
Siemens Genius Siemens Genius
Siemens Genius
@SeanCresswell
Hello Sean,
I am not seeing the same issue when I upload my assembly with frame elements.  I would like to take a closer look at this specific assembly.  Is this an assembly that you can share?  Is so, and all the files are uploaded, you can just share the portal project with keith.cain@siemens.com.
Keith
Project Test Eng Adv
Mainstream Eng
Siemens Industry Sector
Siemens Product Lifecycle Management Software Inc.
* Opinions expressed are my own.
Thanks @KeithCain.......shared that project to you now. Maybe it was something I did, and as I said, it is the only frame assembly I have tried it with. There are other PAR files that arent working in there also.
Siemens Genius
@SeanCresswell
Hi Sean,
With a quick look I see an issue that is causing part files to fail.  We have found that file names containing text inbetween brackets [xx] causes a problem.  We have a fix for this issue and hopefully will be pushing it up to the server soon.  I will relay to you when the push happens.
I opened the assembly file in Design Manager and removed all brackets from the file names and uploaded to the portal.  I didn't see any failures.
One quick note:
Currently 2D drawing files will not have an image displayed in carousel.
Keith
Mainstream Eng
Excellent, see, I knew it was something I did. Robot wink
Thank you very much @KeithCain.
Siemens Genius
@SeanCresswell
Hello Sean,
The fix has now been pushed to the Solid Edge Portal.  I've uploaded your original files and all files succeeded.  Please let me know if you have any additional problems.
Keith
Mainstream Eng
Thanks @KeithCain,
I am currently re-uploading those problem files......they seem to be taking a long time.
But, sounds like it should be a success....thanks for adapting to suit my odd file naming schema. Robot wink
