Download presentation model Solid Edge 2019
Where I could download models and assemblies to the Solid Edge 2019 presentation project called "Bottle Carousel" Thank you for answer.
Jan Ferdan
Re: Download presentation model Solid Edge 2019
This is a customer supplied demo set,  as such I do not believe it will be made available for download.
Matt Johnson
Solid Edge Certified Professional
Solid Edge 2019 (SEEC) - Production
NX12 (Tc Integration)
Teamcenter 10.1.7
Siemens Genius Siemens Genius
Siemens Genius
Jan, it seems like you work for an authorized solution partner of Siemens. Is that correct? If yes, then you or someone in your organization should have access to our "sales center" - and you can download the demo files for Solid Edge 2019 from there. The link to the correct area is here: https://sales.industrysoftware.automation.siemens.com/sell/solidedge/technical/demonstrations/whats-...
Let me know if this does not work for you - and who you work for - and there may be another way to get the files to you
best regards
Dave
{David Chadwick}, {Solid Edge Portfolio Development}, {Siemens PLM Software}
