Incorrect display special characters and incorrect formating draft files
Drafts which have a text with special characters in the label, or in the text filed on the drafts, this drafts are incorrect displayed on the SE Portal (In Solid Edge is all correct). All formating is broken. Special characters are important for our customers.
If I uploaded some drafts on the SE Portal with more than 1 list, the lists are over and over. Please add support for more lists draft files.
Test data: 9212496.zip
Betreff: Incorrect display special characters and incorrect formating draft files
Hello @marekprichystal,
this is a general problem of text fonts, format and CAD.
If you try to use the solid edge portal for sharing files with a customer or a supplier it is also great to upload a PDF file or graphic file (png/jpg).
Than you can be sure your customer can see the same like you.
International it is a problem with fonts US / EU / JP / CH all have different styles and special symbols so native files are in viewing a problem.
Best Regards
Wolfgang
Re: Incorrect display special characters and incorrect formating draft files
Thanks for reporting the two problems.
We are aware about both the issue problem and we are trying the figure out the solution for the same.
Sukrut Gadre
Solid Edge Planning.
