05-30-2018 01:28 PM
What causes an error for a file to not be viewed? file size is 182 mb
ugly red exclamation mark
05-30-2018 04:03 PM - edited 05-30-2018 04:03 PM
Hi Craig,
I'm seeing a problem viewing a *.JT file also.....even though, mine is uploaded OK, and I do get it shown in the part preview carousel, I can not open it to view, in the same way as the *.ASM does....I will delete and re-create to upload it for testing.
I wonder if it's more to do with the file size then.......as I have a 43MB JT file from Ryan McVay [sorry can't share any more than that] and that opens fine.
05-30-2018 04:48 PM
Hello @Craig_H,
have done a test here too.
All is running fine with JT file.
Sorry have not a free JT file with 100 MB to upload for a new test.
best regards
Wolfgang
05-31-2018 09:09 AM
Hi @Craig_H and @SeanCresswell
Is it possible to share the project containing the failing JT file? I would like to take a closer look at the files and see what is happening.
keith.cain@siemens.com
Keith
Project Test Eng Adv
Mainstream Eng
Siemens Industry Sector
Siemens Product Lifecycle Management Software Inc
05-31-2018 12:33 PM
@KeithCain wrote:Hi @Craig_H and @SeanCresswell
Keith
Mainstream Eng
I can, thru portal?
05-31-2018 12:35 PM
Yes, if you can share the project through the portal with keith.cain@siemens.com, I can look at the file(s).
Keith
Mainstream Eng
05-31-2018 12:39 PM - edited 05-31-2018 12:40 PM
Keith
Mainstream Eng
Done! The project is the latest in the Hackrod project (New Siemens partnership) Was kinda bummed as I needed to share it quickly and this i thought would have been the quickest.
05-31-2018 04:13 PM
Shared mine @KeithCain.....in fact, it the same one you helped me with, when frames weren't showing.
05-31-2018 05:18 PM - edited 05-31-2018 05:43 PM
Thank you for sharing the project. I've tried uploading the JT myself and it fails. I was able to open in Solid Edge without any issues. I'll be logging a issue with development and will update you with the bug number.
Thanks for sharing the project. I remember this assembly. Looking at the file name it seems that it contains brackets. I believe this was a problem initially with this assembly failing to upload but the upload issue has been corrected. Unfortunately the viewer has not yet been corrected, so viewing of files with [] or % in the name is failing. The following bug has been filed and I have set the priority to 'High'.
Bug 104732:BUG: Unable to view files with % or [] in name
Would you mind renaming the JT file, removing the brackets and uploading again? I'd like to verify this is indeed the issue.
Keith
Mainstream Eng
05-31-2018 05:27 PM
Thanks @KeithCain, that is indeed the issue with my item....it works as expected now.
