Solid Edge Portal - Fails to view NX 12.0.1 data
To whom it concerns,
uploaded and tried to view a simple model from NX 12.0.1 in the Solid Edge Portal.
The portal did quit the upload with an error that this data could not be viewed.
Is this going to be fixed in the future?
With kind regards,
Stefan Gareis
Re: Solid Edge Portal - Fails to view NX 12.0.1 data
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
Thanks Stefan. We will have someone take a look ASAP.
Siemens Genius Siemens Genius
Siemens Genius
Hello @StefanGareis
I have reproduced the issue and a bug has been filed.
Bug 106357:  NX 12.0.1 files fail to translate
I will post an update once there is additional information.
Keith
Project Test Eng Adv
Mainstream Eng
Siemens Industry Sector
Siemens Product Lifecycle Management Software Inc
* Opinions expressed are my own.
Thank you!
Do you need further logs?
With kind regards,
Stefan Gareis
Siemens Genius
Hi @StefanGareis
Thank you but fortunatly I have NX 12.0.1 installed and was able to create the necessary test case.
Keith
Mainstream Eng
