Solid Edge ZIP-Archive - Viewing
Hello to all Edgers!
i´m use the Pack+Go function to get all files (part+asm) plus the attached drawings and put them into a ZIP-Archive - great. Next step is to load this zip-File with a single click to the Solid Edge Portal - the Viewing of the 3D data works fine. But how can i see, find and view the attached drawings from the Parts or Assembly.
Have you a idea? Thank you for your help.
Lutz !
