Solid Edge draft files
Can the solid edge draft files be loaded into solid edge portal without it being converted into some downgraded text like version?
If I have a hyperlink added to my draft I would like the ability to be able to access it just like in Solid Edge.
For me I can see using the portal to store company specific documents (weld procedures, quality document, etc.) in one project folder. I want to place a hyperlink on the draft that will direct the user reviewing the draft through Solid Edge portal to the document pertaining to that job.
This gets me closer to a paperless environment.
4 REPLIES 4
Re: Solid Edge draft files
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
This is a good suggestion. I am curious how you do this today?
We use Fusion 360 for CAM for machining and it gave us some space on A360.
I would like to keep this all Solid Edge based.
Hello @mezcofab,
your Idea is real great. It makes all a bit simpler. It is great for documentation, description, sales and much more.
Now the big "but" as long as "Siemens" has all rights behind yours and we all place everything on not controlled servers from our side it is like Google or Facebook work.
Here it is necessary to catch the software from Siemens on own controlled servers (net) than it can be very great.
This is for our company and me a big point because of similarity of products to other.
Best Regards
Wolfgang
The issue I see with this is the organization of those documents. So, far you can't have folders. So you are looking at creating projects for document organizations.
