Visualisation Viewer
Gears Legend Gears Legend
Gears Legend
here an example from SkyDrm how there is a simple plant is looking.
The different to Solid Edge Portal is that much more functions are existing and a link sharing is possible.
Have not found the functions in Solid Edge Portal
https://jt2go.skydrm.com/rms/main#/personal/viewSharedFile?d=847b6c37-a850-4401-932c-a8401bd1519b&c=...
One thing is not fine in SkyDrm if you measure something you must reset the view to remove the dimension.
In Solid Edge Portal is right now the new site bar much better than the older on.
Only if you click on a part of a group it pops not up in the structure so you need to search in the site bar where the marked one is. On the other hand, you make a right click and can see the part name?
Best Regards
Wolfgang
