Zip file can not be viewed anymore
Some weeks ago uploading and viewing assemblies, made with pack and go (zip) worked fine.
If I upload a new file now, in the portal I get the message: file cannot be viewed. What is changed?
3 REPLIES 3
Re: Zip file can not be viewed anymore
Siemens Genius Siemens Genius
Siemens Genius
Hello @Francisco-NL
I'm not seeing the problem when I try uploading a .zip file.  Would it be possible to share the project that contains the .zip file you are unable to view?  I'd like to take a closer look and try to identify the issue.
Share with keith.cain@siemens.com
Keith
Project Test Eng Adv
Mainstream Eng
Siemens Industry Sector
Siemens Product Lifecycle Management Software Inc
* Opinions expressed are my own.
I did send the file by email
Siemens Genius
Hello @Francisco-NL
Thank you for sharing the file.
I have filed an issue with developement on this.  There seems to be one component (33MB) that causes this to time-out when uploaded to Solid Edge Portal.  If I upload the file by itself, it will upload and is viewable without any problems.  Developement will take a look to see why the assembly is failing.
Keith
Mainstream Eng
