Solid Edge crash when opening an .par file
When I open a new Isometric Part or want to change on, the Program crashes. A few days ago everything was ok and i could do what i want, bur now I cant open Isometric Parts.
1 REPLY
Re: Solid Edge crash when opening an .par file
KennyG 2nd Gear
2nd Gear
It appears the crash is a result of the open gl driver from the NVIDIA driver update.  You should revert back to the older driver if that worked.
Production: ST10 MP3
Testing: SE 2019
