Permanent Geometry for Spot Welds
Community Manager
Syncrofit 15.1 now allows the creation of permanent geometry for Spot Welds through the Create Permanent Geometry Utility. The Create Permanent Geometry utility is located along the Spot Weld toolbar.PermanentGeometryforSpotWelds2.png
The Utility can be used to create points and/or vectors that represent the Spot Weld Location. In the Visualization tab of a Spot Weld, the vector and points can be customized to have different colors, shapes, and lengths.PermanentGeometryforSpotWelds3.png
