Plotting engine operating points on its BSFC map with Simcenter Amesim
Knowing how your engine performs in terms of fuel efficiency over its operating cycle is key for its optimization. A convenient way of doing it is to plot the engine operating points (BMEP/torque and engine speed) on the BSFC (Brake Specific Fuel Consumption) map.
BSFC map_2.pngBSFC map
 Thus, you can see if your engine is operating in its most efficient range or if you should change something to the powertrain or the control system.
The video below shows how to quickly build such a plot in Simcenter Amesim:
(view in My Videos)
Hope this helps!
